When I first connected them I had to rig a temporary ground to get them to work. Then I realized I needed to raise them so I could hang the license plate off the bracket and when I did that they worked without the ground but as you can see in the photo they were weak and the backup lights also flashed with them though at a much lower output. Today I installed new stainless nuts and bolts in all three holes and the problem went from the left turn signal to the right, keep in mind through all this the brake lights worked fine. After I plugged the switch in that is.
I added the ground wire to the right side and everything works as it should. I still need to ground the system properly since right now I've only got a ten gauge wire going from the battery to the core support to test the various systems as I hook them up. I'm assuming that once I have proper grounds running to the frame and block everything will work as it should.
