I need a simplified version of the brake warning circuit
- Canonman67
I've installed an aftermarket wiring harness and gauges so I can't use the diagrams on the site. Do I just run power to the light and then down to the valve grounding the other leg there? If so how do I run the ignition prove out circuit? Thanks in advance, Lionel
Re: I need a simplified version of the brake warning circuit
I thought there were two wires to the switch, one to the lamp and the other to 'ign' power. Key switch to 'start' puts power on the lamp leg to test it. The lamp is grounded to the dash.
- Nitekruizer
- Canonman67
And that's why I ask. I had it TOTALLY wrong. Thank you gentlemen.
