1. Checked the fuse, wasnt blown, but replaced anyways.
2. Cleaned contacts in the fuse box. No change.
3. Replaced Brake Light Switch. No change.
4. Pulled my steering wheel and the Turn Signal Switch is pretty nasty.
The wiring in the truck is very clean and no breaks from what I can see- given the running lights still work in the rear, I assumed it was the TS switch and ordered a new one online(no one local had one)... It's a week delivery
Anyone have experience with the wiring in the column, wire colors, to jump the Brake Lights past the TS switch to the Brake Light Switch? I won't have turn signals in the rear, but I only drive 5 minutes to work each day and no one in California uses their turn signals anyways...
Huge Thanks!
