key cylinder
key cylinder
Anyone know how to remove key cylinder from the switch assembly in a 72 F100
Re: key cylinder
You have to have the key to do it.barber42 » Thu Nov 03, 2016 5:06 pm
Insert the key / turn to the "ignition on" position / insert a paper clip into the small pin hole under where the key slides in / put pressure on the paper clip while pulling on the cylinder.
Finding someone with the right diameter pins to re-key is the hard part. You can't just use Schlage or Kwikset pins in a Ford key cylinder.
Re: key cylinder
Correct me if I'm wrong , but I think you turn it to the accessory position , then push in the paperclip and turn the key farther over,and then pull out.
(If you Have a key
(If you Have a key
- hot-rod
Re: key cylinder
@cep62,
yes, your right
yes, your right
