All of a sudden, I am having an issue with the headlight switch blowing the 30A fuse immediately when I start to pull out the knob. I bought a new Wells switch, still occurs. Traced every wire from the switch and could not find anything wrong.
Diagnostics is not me strong suit, so, any ideas on how to track down this gremlin? Maybe I need another ground wire besides the ones by the bulbs?
Keeps blowing the 30A fuse
- WarEagle
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
Re: Keeps blowing the 30A fuse
The grounds are always breaking down on our trucks like that-but shouldn't be the issue to all of a sudden start blowing fuses. Try unplugging one bulb at a time, (then turn them on) to see if is side specific. Unplug the dimmer switch, (which is a problematic area) then try to turn the lights on. The back side of our fuse boxes can also be an issue at times, (ground the hot to the firewall / losing insulation on the wire due to being heated for so many years)."WarEagle"]All of a sudden, I am having an issue with the headlight switch blowing the 30A fuse immediately when I start to pull out the knob. I bought a new Wells switch, still occurs. Traced every wire from the switch and could not find anything wrong.
What year truck is it and have you added anything to the lighting circuit recently? Adding the headlight relay upgrade is the simplest and safest thing you can do to the truck for about $50.
- WarEagle
Jeff,
It's a '72. I did upgrade the entire chassis with a Painless harness. It was working fine. I like the idea of removing the light bulbs. I think I will remove them all, then put back one at a time until the fuse blows again, that way I will only blow 1 fuse instead of multiple. The blade type are getting kinda expensive. If none of the bulbs blow the fuse, or if it blows with them all removed, at least it will narrow the problem down.
Thanks!
Thanks!
- WarEagle
Got it!! removed all the light bulbs and saw what was left. I had ran power to the washer motor and light switch, and the washer fluid switch was shorting it all out.
All good now, ready to night cruise in this cooler weather.
